Dual write to InfluxDB OSS and InfluxDB Cloud
If you want to back up your data in two places, or if you’re migrating from InfluxDB OSS to InfluxDB Cloud Dedicated, you may want to set up Telegraf to dual write.
Use Telegraf to write to both InfluxDB OSS and InfluxDB Cloud Dedicated simultaneously.
The sample configuration below uses:
- The InfluxDB v2 output plugin twice: first pointing to the OSS instance and then to the InfluxDB Cloud Dedicated cluster.
- Two different tokens, one for OSS and one for Cloud Dedicated. You’ll need to configure both tokens as environment variables (see how to Configure authentication credentials as environment variables).
Use the configuration below to write your data to both OSS and Cloud Dedicated instances simultaneously.
Sample configuration
# Include any other input, processor, or aggregator plugins that you want to include in your configuration.
# Send data to InfluxDB OSS v2
[[outputs.influxdb_v2]]
## The URLs of the InfluxDB instance.
## urls exp: http://127.0.0.1:9999
urls = ["http://localhost:8086"]
## OSS token for authentication.
token = "${INFLUX_TOKEN_OSS}"
## Organization is the name of the organization you want to write to. It must already exist.
organization = "ORG_NAME_OSS"
## Destination bucket to write to.
bucket = "BUCKET_NAME_OSS"
# Send data to InfluxDB Dedicated instance
## The URLs of the InfluxDB Cloud instance.
urls = ["https://cluster-id.a.influxdb.io"]
## Cloud token for authentication.
token = "${INFLUX_TOKEN}"
## For InfluxDB Cloud Dedicated, set organization to an empty string.
organization = ""
bucket = "DATABASE_NAME"Was this page helpful?
Support and feedback
Thank you for being part of our community! We welcome and encourage your feedback and bug reports for InfluxDB Cloud Dedicated and this documentation. To find support, use the following resources:
