Use Grafana to visualize data
Use Grafana or Grafana Cloud to query and visualize data from InfluxDB 3 Enterprise.
Detect my InfluxDB version
– Grafana documentation
    Option 2: Command line
Using Grafana Cloud with a local InfluxDB instance
If you need to keep your database local, consider running Grafana locally instead of using Grafana Cloud, as this avoids the need to expose your database to the internet.
To use InfluxDB running on your private network with Grafana Cloud, you must configure a private data source for Grafana Cloud.
InfluxDB data source
The InfluxDB data source plugin is included in the Grafana core distribution. Use the plugin to query and visualize data from InfluxDB 3 Enterprise with both SQL and InfluxQL.
Grafana 12.2+
The instructions below are for Grafana 12.2+ with the newInfluxDSConfigPageDesign feature flag enabled. This introduces the newest version of the InfluxDB core plugin. The updated plugin includes SQL support for InfluxDB 3-based products such as InfluxDB 3 Enterprise, and the interface dynamically adapts based on your product and query language selection in URL and authentication.
Before you begin
Prerequisites:
  • Grafana 12.2 or later
  • Your admin token with read access to the database
Quick reference: InfluxDB 3 Enterprise configuration
ConfigurationValue
Product selectionInfluxDB Enterprise 3.x
URLServer URL–for example, https://localhost:8181
Query languagesSQL (requires HTTP/2), InfluxQL
AuthenticationAdmin or database token (if authentication is enabled)
Database/BucketDatabase name
  2. Click Data sources.
  3. Click Add new data source.
  • URL: Your InfluxDB 3 Enterprise server URL–for example, https://localhost:8181
  • Product: From the dropdown, select InfluxDB Enterprise 3.x
Configure database settings
SQL configuration
Use SQL without TLS/SSL
If using SQL to query InfluxDB 3 Enterprise without TLS/SSL, enable the Insecure Connection option in your InfluxDB datasource configuration:
  1. Under Database settings, enable Advanced Database Settings.
  2. Enable Insecure Connection.
Query InfluxDB using SQL without TLS/SSL
For SQL queries, Grafana uses the Flight SQL protocol (gRPC) to query InfluxDB 3 Enterprise, which requires HTTP/2. If you query InfluxDB 3 Enterprise through a proxy (such as HAProxy, nginx, or a load balancer), verify that your proxy is configured to support HTTP/2. Without HTTP/2 support, SQL queries through Grafana will fail to connect.
Click Save & test. Grafana attempts to connect to InfluxDB 3 Enterprise and returns the result of the test.
InfluxQL configuration
Query and visualize data
Query InfluxDB with Grafana
After you configure and save an InfluxDB datasource, use Grafana to build, run, and inspect queries against InfluxDB 3 Enterprise.
When working with the InfluxDB 3 Enterprise SQL implementation a bucket is equivalent to a database, a measurement is equivalent to a table, and time, fields, and tags are structured as columns. To learn more, see Query Data.
  1. Click Explore.
  1. Click Explore.
Query inspection in Grafana
New in InfluxDB 3.8
See the Blog Post
docker pull influxdb:2
