Select product
InfluxDB 3
InfluxDB 2
Other products
InfluxDB 3 is the current generation of InfluxDB and the recommended platform for new time series workloads—built for high-speed, high-cardinality data from the edge to the cloud.
Not sure which product fits your use case? See Which InfluxDB 3 should I use?
The open source recent data engine optimized for time series and event data.
The scalable data engine built for recent and historical time series and event data.
The Kubernetes-enabled, highly-available InfluxDB 3 cluster built for high write and query workloads on your own infrastructure.
The fully-managed, multi-tenant InfluxDB 3 service deployed in the cloud.
The fully-managed InfluxDB 3 cluster dedicated to your workload and deployed in the cloud.
A standalone UI designed for visualizing, querying, and managing data in InfluxDB 3 Core and Enterprise.
The open source data collection agent with support for a large catalog of data sources and targets.
Centralized Telegraf configuration management and agent observability with an intuitive UI.
Enterprise support for Telegraf and Telegraf Controller, plus higher limits and enterprise features in Telegraf Controller.
The open source time series platform with support for Flux and InfluxQL, scheduled tasks, dashboards, and more.
The fully-managed, multi-tenant InfluxDB v2 instance deployed in the cloud and powered by the TSM storage engine.
The functional language specifically designed for querying and processing data.
The open source single-node InfluxDB v1 instance designed for high write and query workloads.
The highly available InfluxDB v1 cluster built for high write and query workloads.
The web UI that visualizes your InfluxDB time series data and easily creates alerting and automation rules.
The data processing framework for creating alerts, running ETL jobs, and detecting anomalies.
© 2026 InfluxData, Inc.
Also new in 2.9.0:
Highlights:
Key updates in InfluxDB 3 Core 3.11:
Processing engine trigger reliability improvements—capped async trigger concurrency, bounded retries for failed triggers, and WAL triggers that skip empty flushes.
Configurable graceful shutdown with the new --shutdown-timeout option.
Key updates in InfluxDB 3 Enterprise 3.11:
Upgraded storage engine reaches general availability. New
clusters default to Parquet; upgrade with --upgrade-pacha-tree.
In-place and incremental backup and restore.
Integrated Explorer UI—run with --mode all,webui.
Bulk import: import from remote object store sources (for example, S3) with configurable concurrency.
Compaction and query performance improvements.
Catalog migration—back up your catalog before upgrading.
Telegraf Controller 1.1 lets teams make fleet-wide configuration changes with a single edit using global constants, configuration groups, and configuration aliases. Configuration versioning makes every change traceable, comparable, and reversible. High availability, available with Telegraf Enterprise, automatically fails over between Controller instances so agents can continue pulling configurations and reporting health if an instance goes down.
InfluxDB OSS 1.13.0 adds mTLS support, adaptive TSI cache sizing, and a hardening option to mitigate SSRF.
Key updates in InfluxDB OSS 1.13.0:
hardening-enabled option to mitigate server-side request
forgery (SSRF) in Flux HTTP requests.For details, see the InfluxDB OSS 1.13.0 release notes.
InfluxDB Enterprise 1.13.0 adds mTLS support and changes the default replication factor from 3 to 2.
Key updates in InfluxDB Enterprise 1.13.0:
For details, see the InfluxDB Enterprise 1.13.0 release notes.
latest tag for InfluxDB Docker images will
point to InfluxDB 3 Core. To avoid unexpected upgrades, use specific version
tags in your Docker deployments.If using Docker to install and run InfluxDB, the latest tag will point to
InfluxDB 3 Core. To avoid unexpected upgrades, use specific version tags in
your Docker deployments. For example, if using Docker to run InfluxDB v2,
replace the latest version tag with a specific version tag in your Docker
pull command–for example:
docker pull influxdb:2
