Dual write to InfluxDB OSS and InfluxDB Cloud
If you want to back up your data in two places, or if you’re migrating from InfluxDB OSS to InfluxDB Cloud Serverless, you may want to set up Telegraf to dual write.
Use Telegraf to write to both InfluxDB OSS and InfluxDB Cloud Serverless simultaneously.
The sample configuration below uses:
- The InfluxDB v2 output plugin twice: first pointing to the OSS instance and then to the InfluxDB Cloud Serverless instance.
- Two different tokens, one for OSS and one for Cloud Dedicated. You’ll need to configure both tokens as environment variables (see how to Configure authentication credentials as environment variables).
Use the configuration below to write your data to both OSS and Cloud Serverless instances simultaneously.
Sample configuration
# Include any other input, processor, or aggregator plugins that you want to include in your configuration.
# Send data to InfluxDB OSS v2
[[outputs.influxdb_v2]]
## The URLs of the InfluxDB instance.
## urls exp: http://127.0.0.1:9999
urls = ["http://localhost:8086"]
## OSS token for authentication.
token = "${INFLUX_TOKEN_OSS}"
## Organization is the name of the organization you want to write to. It must already exist.
organization = "ORG_NAME_OSS"
## Destination bucket to write to.
bucket = "BUCKET_NAME_OSS"
# Send data to InfluxDB Cloud Serverless instance
## The URLs of the InfluxDB Cloud instance.
urls = ["https://cloud2.influxdata.com"]
## Cloud token for authentication.
token = "${INFLUX_TOKEN}"
## For InfluxDB Cloud Serverless, set organization to an empty string.
organization = ""
bucket = "BUCKET_NAME"
Support and feedback
Thank you for being part of our community! We welcome and encourage your feedback and bug reports for InfluxDB Cloud Serverless and this documentation. To find support, use the following resources:
